plott
Aug 01, 2019Aspirant
Setting up RDP through EX7000
I have a NG Router and NG EX7000 extender - working fine. I'd like to set up RDP for devices connected to the extender. I've set up a static (reserved) IP for the one laptop for which I'll need acc...
antinode
Aug 02, 2019Guru
> I have a NG Router [...]
Model? Firmware version? Connected to what?
> [...] and NG EX7000 extender [...]
Connected and configured how? Firmware version?
> need access.
How? Where? If you did it on the router, then it's reserved
(dynamic), not static. What is that address?
To what is that (unspecified) "the one laptop" connected, how? Can
you make a Remote Desktop connection to that (unspecified) "the one
laptop" from another system on your LAN, using the laptop's (reserved,
dynamic) LAN IP address?
> I've set up port forwarding (port 3389) [...]
What's the actual port-forwarding rule? Can you make a Remote
Desktop connection to that (unspecified) "the one laptop" from another
system on your LAN, using the router's WAN/Internet IP address? What is
the router's WAN/Internet IP address? ("a.b" of "a.b.c.d" would be
enough of your public IP address to satisfy my curiosity.)
> I can't seem to get [there] using RDP. [...]
"seem"? Get to where, from where, how? Did you get some actual
error message when you did whatever you did?
> [...] Do I need to do anything on the extender? [...]
I would think not, but, if I had doubts, then I might try connecting
that (unspecified) "the one laptop" to the router, instead of to the
extender.
> Any other good resources?
I don't know enough yet to suggest any solutions.
plott
Aug 02, 2019Aspirant
C3700-100NA S
V2.02.22
Xfinity
used mywifiext.net wizard - new extender
V1.0.0.66_1.0.126 - I upgraded but everything stopped working, so I backed out the upgrade
> need access.
On router (Address Reservation): 192.168.0.253
This laptop is connected to the the SSID of the extender.
I can get to it via RDP with another machine on the LAN.
24.39...
I cannot RDP from outside the LAN
Port Forwarding Rule:
- Service Name: Remote Desktop
- External Port: TCP/UDP: 3389
- External IP Address: Any
- Interenal Port: TCP/UDP: 3389
- Internal IP Address: 192.168.0.253
Using Windows RDP:
Generic "Remote Desktop can't connect to the remote computer for one of these reasons:
1) Remote access to the server is not enabled
2) The remote computer is turned off
3) The remote computer is not available on the network.
I would connect directly to the router, but I got the extender because there are parts of the house that the router doesn't reach very well - the extender is the solution.
Thanks for your help!!
- antinodeAug 02, 2019Guru
That would seem to absolve the extender, especially if the Remote
Desktop client is connected more directly to the router.Is that using the LAN IP address of the laptop? What about using the
WAN/Internet IP address of the router (from within the LAN)? That
should test the router's port forwarding (unless its NAT loopback
feature is broken).> I would connect directly to the router, but [...]
Yeah, but a short test might be interesting.
Is there some Windows Firewall setting which is needed for off-LAN
access?
Otherwise, it all looks plausible to me. However, if you ever do get
it to work, then you might want to use a different (non-default)
external port number, to avoid making yourself an easy target for
malrfactors.- plottAug 02, 2019Aspirant
So, I got frustrated and rebooted the router.
RDP then worked.
Thanks, again!
