zpower
Feb 02, 2012Novice
Setting up VLAN using WMS5316
Hello, I wanted to know if someone could provide some help setting up VLANs on the WMS5316. I would like to have a VLAN separate from my management VLAN so I can use MAC authentication on the WMS5...
Marto731
Feb 25, 2012Aspirant
To Zpower,
We don't know what router you have, and whether it is "Vlan aware".
For 2nd Vlan, you will need a 2nd DHCP pool. Tie each Vlan to a different profile & SSID.
Or you could work with a Layer 3 switch. Again I don't know your switch or AP type. I need a fuller network description.
Regards Marto :o
Regards Marto :o
