nickboland
Jun 13, 2012Novice
Setting Up Wireless Bridge
I'm trying to setup a wireless bridge between my main router (WNDR3700 - main floor) and my old one (WNR2000v2 - basement). I have no idea where to start... All I want to do is have the WNDR3700 ru...
nickboland
Jun 15, 2012Novice
sooo I'm just trying the whole wireless repeater thing right now.
right now my dual-band is broadcasting and I've got my WNR2000v2 plugged into 1 of the LAN ports (into another LAN port). I'm getting my usual network signal + a 'NETGEAR' signal, which I assume is from the router I'm trying to use as a repeater.
I went to 'wireless repeating' and tried to setup the WNR2000v2 and it didn't go well. I just put everything back to normal with the dual-band and turned the WNR2000v2 off. I'm guessing I may have to setup the dual-band router as a repeating base station first?
I'm just a little lost, ahah.
