sethfeinberg
Aug 11, 2012Aspirant
Setting WNDR2000v2 up as Wireless Bridge
I currently have a WNDR3700 as my main router/base station and a WN802Tv2 hard-wired w/ ethernet acting as a wireless bridge (not strictly the repeater function). I just purchased a WNDR2000v2 and wo...
sethfeinberg
Aug 13, 2012Aspirant
I ran through all the steps again and it again lost the new IP configuration. Then I noticed something about NEVER using the ethernet port anymore on the Access point. I didn't use it during setup but after everything was set up I plugged the ethernet cable into the ethernet port, thinking that was the only port that could "feed" the access point ethernet. Well in any event, it seems to be working now, so hopefully my boneheadedness helps someone else...
