psyeinstein's avatar
psyeinstein
Follower
May 15, 2016
Setup a new WN2000RPT without PC
I need to buy some repeater. So I choose this one but I don't have any PC with me right now and I need to ask do I can to setup the router without LAN cable via Iphone thanks.
  • DarrenM's avatar
    May 23, 2016
    Hello psyeinstein
    Yes you can setup the device with a phone you can use the WPS to connect it to the router and you should be able to connect via the phone and go to the setup website.
    DarrenM
