mcd4959
Sep 03, 2011Novice
Setup hangs on "Apply Security Settings" screen
Bought a new router this week - Netgear N600 WNDR3400. I had an older Netgear router it replaced. For some reason, after working seamlessly for months, I started getting DNS errors. Did a little re...
jmizoguchi
Sep 03, 2011Virtuoso
WPA2 encryption should work the best and extender is 2.4ghz only so make are both band is enabled in router interface for wireless
