mcd4959
Sep 03, 2011Novice
Setup hangs on "Apply Security Settings" screen
Bought a new router this week - Netgear N600 WNDR3400. I had an older Netgear router it replaced. For some reason, after working seamlessly for months, I started getting DNS errors. Did a little re...
mcd4959
Sep 03, 2011Novice
That did the trick! I had to manually type in the name of the network - if I just cliecked on it as one of the avaialble networks, it would hang. By typing in the name of the net it moved on.
Weird but it worked. Thanks for your help!
