AKZutshi
Apr 18, 2020Follower
Setup issues
I have set up my new Netgear EX6150 WiFi extender using the WPS set up process, and I do see the two MyNetworkname_2GEXt and the _5GEXT networks. However, when I try and connect a mobile device to e...
Apr 18, 2020Guru - Experienced User
1. what router are you using?
2. firmware on the extender?
3. I'd recommend re-running setup using the installation wizard and not wps. Different device makers code wps different. It can create issues which is why there's also the setup wizard. Try that.
