belliott4488
Dec 20, 2012Follower
Should access point SSID/key match main router's?
I have just purchased a WRN2000v3 wireless router to use as an access point to extend the range of the wifi router supplied by my ISP (Verizon FiOS). The routers are connected LAN-to-LAN by ethernet cable, as described in Netgear's instructions.
Am I correct to use the same SSID and WPA key for both routers? This makes sense to me so that hand-held devices can communicate with whichever router has a stronger signal as I move throughout my house, but I have not seen any instructions on Netgear's website that suggest doing this.
Thanks for any advice.
1 Reply
- jmizoguchiVirtuosoWNR2000 is NOT access point device. It is wireless N router
belong to http://forum1.netgear.com/forumdisplay.php?f=33
