davidgarratt's avatar
Jan 28, 2023
Should I replace my EAX80 or reconfigure it ?
So my config looks like this. I have 3 x EAX80 Mesh Wifi Extenders in Access Point mode hard wired back to a Draytek 2962 router. I have manually selected different channels for 2.4 and 5 ghz networ...
  • plemans's avatar
    Jan 29, 2023
    The "mesh" part of it works perfectly fine in extender mode. In access point mode though, smart roaming features are disabled as its function as a single access point, not as part of a mesh. Its why you're devices don't roam very efficiently (or not at all).
    If you're wanting a full mesh device, then you need to get something like the MK nighthawk system or orbi system.
    good thing is you have hardwired backhauls. With a hardwired backhaul, a cheap dual band system will perform pretty great.
