davidgarratt
Jan 28, 2023Guide
Should I replace my EAX80 or reconfigure it ?
So my config looks like this. I have 3 x EAX80 Mesh Wifi Extenders in Access Point mode hard wired back to a Draytek 2962 router. I have manually selected different channels for 2.4 and 5 ghz networ...
- Jan 29, 2023
The "mesh" part of it works perfectly fine in extender mode. In access point mode though, smart roaming features are disabled as its function as a single access point, not as part of a mesh. Its why you're devices don't roam very efficiently (or not at all).
If you're wanting a full mesh device, then you need to get something like the MK nighthawk system or orbi system.
good thing is you have hardwired backhauls. With a hardwired backhaul, a cheap dual band system will perform pretty great.
davidgarratt
Jan 28, 2023Guide
And yet the product is called :
AX6000 WiFi Mesh Extender (EAX80)
Nighthawk® AX8 WiFi Mesh Extender, 6Gbps
Jan 29, 2023Guru - Experienced User
- davidgarrattFeb 01, 2023Guide
I've decided to replace my router and EAX80's with an Orbi Mesh system. Hopefully that will streamline things a bit.
Anyone wants 3 x EAX80's I'm open to offers 🙂
Dave
- plemansFeb 01, 2023Guru - Experienced User
Those are some expensive devices. Maybe just try it for a bit in extender mode and see how it works 🙂
Or go all out and switch to the mesh, Whatever works best for you.
- nrosenbFeb 01, 2023Aspirant
I'm curious, how did the EAX80s perform in extender (vs AP) mode?
