Gili756
Jul 12, 2018Aspirant
Signal Strength LED stays on RED continuously
Something bizarre is happening with my unit: per instructions I located the unit in the same room with my dual band router (actually, about 2 feet away from it), and began setting it up. Now the strange part begins: first, the unit absolutely refuses to connect to the 2.4 GHz band; it only connects to the 5.0 GHz band; second, even though the unit is two feet away from the router, the signal quality LED stays on red continuously regardless of what I do.
How could the signal quality be poor, when the extender is so close to the router, and wifi analytics shows 3-4 bars of signal strength?
- DarrenMSr. NETGEAR Moderator
Make sure the unit is on the latest firmware and them you may want to try and factory reset the unit by holding the reset button for 10+ seconds then set the extender up again.
DarrenM
- Gili756Aspirant
Actually, all has been resolved without a factory-reset. It turns out my 2.4GHz band became disabled during the initial setup. Once I reran the smart setup, I was able to reactivate the 2.eGHz band. Now both bads are active, and all LED's on my extender are a steady white. I haven't had any other issues since running the smart setup. I am a very happy person right now.
