TrevNet
Sep 17, 2015Aspirant
Simple Extender for Virgin Super Hub (VMDG480)
Hi, I have a small house with the Virgin Super Hub (VMDG480) positions at the front of the ground floor and am not gett great signal at the back bedroom on the 1st floor. Can anyone point me tow...
nhann
Sep 18, 2015NETGEAR Employee Retired
Hi TrevNet,
If the back bedroom is still within the same electrical circuit as your front of the ground floor, then you may consider the NETGEAR Powerline:
http://www.netgear.co.uk/home/products/networking/powerline/
You can also run a comparison between the WiFi Range Extenders to see which one fits your requirements:
http://www.netgear.co.uk/home/products/networking/wifi-range-extenders/
TrevNet
Sep 20, 2015Aspirant
Thanks Nhann,
I talk to my electrician (unless there is any easy way to tell?). If it's not on the same circut, are there any other options?
Thanks again.
- nhannSep 21, 2015NETGEAR Employee Retired
You're welcome.
If it's not on the same circuit, then you can also consider the WiFi Range Extender products mentioned above (does not require same circuit).
