albgen
Jun 14, 2009Aspirant
SIP Alg on netgear routers
Hello, i have an IP Phone which does not recieve calls if the SIP Alg feature is enabled!!! Disabling it my ip phone can recieve calls! why it mess all when its switchen on?
albgen
Jun 21, 2009Aspirant
This feature not only dont work, but it adds trouble to the sip protocol!!!!!
I have a Netgear DG834N. On the lan side, is installed a sip hardware phone and on the the computer i have installed a client software sip.
On both(hardware and software sip), if the "sip alg" feature is enabled i cant recieve calls! Instead, if "sip alg" is disabled then i can recieve calls.
ps:there are no problems on outgoing calls.
