albgen
Jun 14, 2009Aspirant
SIP Alg on netgear routers
Hello, i have an IP Phone which does not recieve calls if the SIP Alg feature is enabled!!! Disabling it my ip phone can recieve calls! why it mess all when its switchen on?
jmizoguchi
Jun 21, 2009Virtuoso
albgen wrote: maybe fixing the firmware router could be e a better solution than exposing my ip phones on the dmz
I don't see huge issues putting IP phone on DMZ but bug in a firmware should be fixed
also in Prosafe Routers, few new firmware add way to disable SIP ALG in command line as well.
report your finding by opening the case
https://my.netgear-support.com/myNETGEAR/ENG/login.asp
