Falkie
Aug 02, 2023Aspirant
Slow EX2700
I have two wifi range extenders - both are EX2700 and the firmware is the latest (which is v1.0.1.72). I have FTTP with BT in UK, and when I check the speed when linked to laptop via cable to the BT ...
- Aug 03, 2023
Falkie wrote:
Many thanks for your prompt response.
Can you suggest a suitable product ?
What do you want to achieve?
Try plugging your needs into the filters on the product pages:
WiFi Boosters & Extenders | Wifi Range Extenders | NETGEAR
and
Wireless Routers for Home | NETGEAR
Then check back here for reports on the things you are considering, but remember that people turn up in this community with problems, not compliments. So look at reviews on Amazon, for example.
Falkie
Aug 03, 2023Aspirant
michaelkenward
Aug 03, 2023Guru - Experienced User
and
