Wolfen620
Mar 23, 2020Guide
Slow speeds on extender
I am getting slow speeds on my extender using the nighthawk app speed test. I am getting 160 down and 40 up. The ex8000 is on firmware .202. My router is an rax120 on firmware .214. The router is get...
Wolfen620
Mar 23, 2020Guide
Thanks I'll give it a try.
Wolfen620
Mar 23, 2020Guide
Ok plugged a laptop directly into extender and it is not showing a internet connection on the laptop. WiFi connection is the only thing showing up. I tried 2 different cables same result.
- plemansMar 23, 2020Guru - Experienced User
Try a different device, different cable, and/or resetting the extender back to factory.
- Wolfen620Mar 23, 2020Guide
That didn't work either. Got off the phone with tech support and they couldn't figure it out either. They changed a couple settings, set it up as new and same problem. She said to monitor my slow speeds for 12 to 48 hours and if they are the same to call back. ☹️ I think it will be getting a RMA.
- Wolfen620Mar 25, 2020Guide
Ok one more question before I return this to Best Buy. My slow speeds continue and I get no internet signal when hardwired to the extender. My firmware says it's .206 but the latest firmware listed on the site is .202. Could this be the problem? I don't know where this .206 firmware came from.
