Panthera75
Jan 13, 2013Aspirant
SMC Xfinity Router/Modem Combo not compatible
I wanted to get the word out incase anyone had an SMC Xfinity Router/Modem combo. I spent HOURS trying to set up my Netgear WN2000RPT wifi extender. After two long days and an addition hour with Netgear tech support, we both decided to give up. Until I read that Xfinity's SMC router/modem combos aren't compatible with much of anything. So I hooked up my Linksys, used it as my default router... then made one last attempt at the Netgear... and I was up and running in just a couple of minutes, easy as pie. I was ready to return my product until I used a different router. Hope this helps.
- Panthera75AspirantOopps double post. .can someone delete this one? Thanks
- jmizoguchiVirtuosoIt's okay leave it alone
Duplicate thread and active thread will be here
http://forum1.netgear.com/showthread.php?t=82889
