mlefmann
Jul 19, 2019Follower
softtree scam
I just spent 45 minutes with a "tech" person trying to set up my extender as I have a new U-verse network. This person was IN my computer. I followed a netgear.com link. He goes through all these com...
Inter-Barb
Dec 06, 2019Guide
Hi AzzaF,
Could you please tell me where you got the manual? Was it online?
AzzaF
Dec 08, 2019Tutor
It was some months ago but they must have made contact via the web.
When I had a problem with the installation and set up I must have gone to Netgear for help and somehow Apple Tree came on line.
However the Netgear Genie seems to function.
Not sure how I check that my laptop is secure.
- Inter-BarbDec 12, 2019Guide
The easiest way to check if your firewall is on is to type "windows defender firewall" in the search box near the windows icon at the bottom left of your screen. The windows defender firewall will come up in the control panel system/security for windows 10 users. From there, you will be able to see if your firewall is enabled (green check) and change the setting if it isn't.
