FullyFamous
Jul 07, 2021Aspirant
Software update
I'm trying to update the software on my EX2800 range extender. Don't even know if it needs to be updated, but never hurts to try. I have the wireless set up on my HP Chromebook, but Chromebook says t...
Jul 07, 2021Guru - Experienced User
1. try to access it using its ip address (can be found in the routers connected devices page)
2. you don't "open" the file. You download it, extract it, and then that'll get uploaded to the device when you follow the manual update process.
How do I manually update the firmware on my NETGEAR WiFi Extender? | Answer | NETGEAR Support
FullyFamous
Still having problems doing what you said. Is this a Chromebook issue? (I have problems installing a WI-FI printer, too. So it goes.
- plemansJul 07, 2021Guru - Experienced User
What problem are you having? you need to let us know where in the process its failing.
We need details as "its having problems" doesn't tell us much.
