dipb
Oct 14, 2012Aspirant
Sony UWABR100 not able to detect DGND3700 wilrless N signal
HI,
I have a Netgear Dual Band DGND3700 router transmitting N signal at 157 channels and 300mbps mode.
I also have a Sony EX550 Internet TV with Sony's UWABR100 USB internet dongle which is N compatible.
However, when I try to scan for available networks, the TV can only see the G signal and can connect. It cannot see the N signal at all.
Please help what needs to be done if I am missing any settings here.
- jmizoguchiVirtuosoDGND3700 is NOT access points.. it is WIRELESS/WIRED ROUTER
Belongs to http://forum1.netgear.com/forumdisplay.php?f=33 - dipbAspirantSorry.. I did not understand what you are trying to say..
DGND3700 is a wirless router. But it does act as an access point.
An access point is through which you access.
The question I have asked here is that DGND3700 is transmitting at both 2.4GHz and 5GHz (n network). However, Sony dongle can only see the 2.4GHz signal. Sony claims it is supports a/b/g/n network.. then why I am not able to see the n network or how can I see ?? ?
If you can solve the problem, pls reply back. - jmizoguchiVirtuoso
doesn't matter.
posted on wrong area - dipbAspirant
jmizoguchi wrote: doesn't matter.
June.. moved. now answer only if you know the solution.
