medicineman4040
May 18, 2022Initiate
Sorry if this has been posted.....EX7300+Starlink Gen 2
Google found precious little if nothing applicable so may I ask for suggestions on setting up EX7300 with Starlink Gen 2. Obviously Starlink has no WPS so manual setup is required. BUT my Starlink ...
May 18, 2022Guru - Experienced User
The starlink doesn't have security setup on it?
If it requires a wireless password to assess it, it either needs a wps button or you need that wifi password.
If it doesn't have a wifi password, its even easier to setup the extender.
You just use the installation assistant to set it up and not wps.
