Eagle-Eyes
Mar 22, 2023Aspirant
Speed problem with NETGEAR AX1800 Wifi extender (EAX20)
My NETGEAR AX1800 Wifi-Extender (EAX20) , just around 1 month old, suddenly reaches only a fraction of the wireless LAN speed in my home network compared to the speed that was reached before. I have ...
Mar 22, 2023Guru - Experienced User
Do you have the screensnip of the status page for the extender?
Have you tried changing the channels the main router is on?
Whats your old extender?
when you setup the extender, are you using wps?
Eagle-Eyes
Do you have the screensnip of the status page for the extender? - No, but there were no error messages anywhere.
Have you tried changing the channels the main router is on? - Yes, I tried that and selected channels, which were in least use. No change.
Whats your old extender? - A TRENDnet TEW-800MB.
when you setup the extender, are you using wps? - Yes - or rather both, i.e. I tried it both ways. With WPS and with the repeater configuration setup.
- plemansMar 22, 2023Guru - Experienced User
The status page helps us to check it. there really shouldn't be any errors on it.
But it helps us. Please include a screensnip.
Also, what wired speed do you get from the extender?
What router do you have it connected to?
that extender is a basic AX1800 extender. If you don't have an AX router, its not going to see any speed benefit over the trendnet as it'll connect around those same speeds as the trendnet in AC.
