jn865
Nov 01, 2011Aspirant
Static route with WG302 V2
Hi, I am trying to get a WG302 to work on a different subnet for the wireless. This is how the setup is: WG302 - IP address is 172.16.100.2, DHCP scope is 172.16.100.110 - 254 Default gateway...
jmizoguchi
Nov 01, 2011Virtuoso
if your primary DHCP uses 172.16.100.x then assuming you doing like
main router DHCP 172.16.100. 3~172.16.100.109
and you are trying to use WG302 DHCP 172.16.100.110-254
if this is how you are doing it?
how you are routing...?
which is connected to a firewall with a static route in place
