jn865
Nov 01, 2011Aspirant
Static route with WG302 V2
Hi, I am trying to get a WG302 to work on a different subnet for the wireless. This is how the setup is: WG302 - IP address is 172.16.100.2, DHCP scope is 172.16.100.110 - 254 Default gateway...
fordem
Nov 01, 2011Mentor
A WG302 cannot route - it's not a router. If you set it to issue a different ip range you'll need to have the upstream router perform the routing tasks - if it can - not all routers support subinterfaces and multiple local networks.
