afsac
Mar 24, 2014Follower
Strange MAC Address Showing -- on "refresh" only!
I've been using the WNR 2000 for about two years now, no problems. I recently logged into the router to change the password for the the Wifi network, and when I checked the Attached Devices it shows a...
theLocust1313
Jan 07, 2015Aspirant
I've encountered the same issue. I noticed the problem after my data usage increased near/over my ISP's allowance over the past few months. Previously, I have not even received the "nearing your limit" warning from the ISP.
The IP and MAC addresses are not mine on refresh. They also change pretty quickly. After refreshing a few times over the course of a minute, several disappeared and new ones arrived. I've restored to factory, powered off/completely unplugged it many times, verified I have the latest router update, enabled only MAC addresses that are used in the household, and intentionally caused random and lengthy local outages by powering off the router. I have not disabled SSID broadcast, although that's a next step after a few more tests.
Looking for an explanation if it's normal or if it's abnormal. Any help would be appreciated. Thanks!
