Ocin70
Feb 10, 2021Follower
stretching the signal
Hi there, I have two questions: 1) is there a possibility to connect satellites amongst each other with an ethernet LAN cable to strech the signal? 2) Is there a Netgear Powerline system that works...
- Feb 11, 2021
Ocin70 wrote:Hi there, I have two questions:
1) is there a possibility to connect satellites amongst each other with an ethernet LAN cable to strech the signal?---yes you can connect satellites to each other over a lan cable.
2) Is there a Netgear Powerline system that works with the Orbi system?---orbi doesn't have powerline built in so any powerline system that sets up/connects, should work.
Thanks!
Feb 11, 2021Guru - Experienced User
Thanks!
- halleahyFeb 21, 2021Initiate
Thanks! I will work on it.
