grandixximo
Aug 02, 2013Novice
SUggestions on how to setup 3 wifi extender
I bought 3 wifi extender WN3000RP i want to bridge one over the other to extend my wifi I have run into some problems, my original wifi router is a CISCO NAV10-WF (Navigator) So i setup the f...
grandixximo
Aug 02, 2013Novice
Just noticed something, i tryed to use the third repeater i had and set it up like the second.
i noticed something, after the second repeater tryes to connect i go and see his status and the gateway and DNS are 0.0.0.0 both, then i connect to the first router and it's the same 0.0.0.0
but before the first one was correct 192.168....
so they are conflicting with each other or something, have no idea, at this point i'm not sure it's even possible to do what i'm asking with this device.
