grandixximo
Aug 02, 2013Novice
SUggestions on how to setup 3 wifi extender
I bought 3 wifi extender WN3000RP i want to bridge one over the other to extend my wifi I have run into some problems, my original wifi router is a CISCO NAV10-WF (Navigator) So i setup the f...
grandixximo
Aug 03, 2013Novice
I'll leave this for future reference to anyone having this problem
the WN3000RP is unable to work in a cascade connection.
it's not possible to connect multimple WN3000RP to each other, they can only be connected to other access points which are wired to a network.
you can connect more than one to the same access point, but you cannot connect an extender to another extender, at least not the WN3000RP.
The fact that this repeater is unable to be connected in cascade should be specified on the manual.
Anyway the shop where i bought them it's taking them back.
thanks for your help jmizoguchi, you were right you would lose 50% with other extender able to do cascade connections, but the WN3000RP don't do cascade.
