Punimadi
Aug 20, 2020Aspirant
Supply voltage for WNR1000
Hello Team, What is the supply voltage for WNR1000 is it 12V , 1A? What is the approximate price
Aug 20, 2020Guru - Experienced User
Its a 12 volt power supply.
netgear doesn't sell a replacement but you can get 3rd party ones off amazon. Or you might even have one sitting around from a different device. It needs 12v and at least 1amp. You can have a higher amperage but will run into issues if you have less.
