jsk125
Nov 01, 2025Aspirant
Support Problems
I purchased a Netgear AC750 Range extender. I have not been able to make it work. And I had two calls to support. Issue: Seems I need to somehow enable non htps in my browser. I can connect t...
- Nov 03, 2025
Update: I fixed it by using a different browser that enabled me to get to the installation site .. however, the original call I made was a number in the document provided with the device. All good now ... though it took a while
jsk125
The telephone number was in the documentation in the instructions on in the box. The second time I called was a number on your website
- StephenBNov 01, 2025Guru - Experienced User
This is a user-to-user forum, and I don't work for Netgear.
Were you using this URL?
- https://www.netgear.com/support/home/
