ake1000
Nov 04, 2020Follower
surface will not connect to extender wn2000
I can not get my pc (surface) or my phone (android) to connect to my extender wn2000rvp. The extender is connected to network and shows green. I can connect to the main router Ive reset down l...
Nov 04, 2020Guru - Experienced User
What router did you connect the wn2000rpt to?
what firmware is on it?
Did you set it up using wps or using the installation assistant?
