8ballpoolapk11
Jan 07, 2025Follower
suugest me a wifi router
Looking for recommendations on a reliable Wi-Fi router under $100 that supports strong signal coverage for a 3-bedroom house. Any suggestions?
Jan 07, 2025Guru - Experienced User
My suggestion? Check amazon for renewed routers.
the RAX70 can usually be found for that price renewed and so can the RAX50.
both would get you to a solid single router solution.
If you're wanting a mesh, you'd need to up the budget a bit for what I'd recommend.
