SAG1
Feb 27, 2022Tutor
Switching from Extender to AP (Model EX6400)
I have the AC1900 WiFi Extender Essentials Edition (model EX6400). I originally set it up as a Extender which worked well but now I want the AC1900 to be and AP. What I did was connected a Cat5 cab...
- Feb 28, 2022
Glad its working as it should!
If you mark it solved, it keeps others from trying to fix it still :)
Feb 27, 2022Guru - Experienced User
I usually re-run setup but if its working as it should, I wouldn't worry about it.
did you log into its settings page to ensure its running as an access point and not still in extender mode? (shouldn't be an issue)
- SAG1Feb 28, 2022Tutor
I just got in to my settings and it does say Access Point.
That was a very easy changeover.
THANKS for the help in confirming that all is well.
SG
- plemansFeb 28, 2022Guru - Experienced User
