SAG1
Feb 27, 2022Tutor
Switching from Extender to AP (Model EX6400)
I have the AC1900 WiFi Extender Essentials Edition (model EX6400). I originally set it up as a Extender which worked well but now I want the AC1900 to be and AP. What I did was connected a Cat5 cab...
- Feb 28, 2022
Glad its working as it should!
If you mark it solved, it keeps others from trying to fix it still :)
Feb 27, 2022Guru - Experienced User
I usually re-run setup but if its working as it should, I wouldn't worry about it.
did you log into its settings page to ensure its running as an access point and not still in extender mode? (shouldn't be an issue)
SAG1
Feb 28, 2022Tutor
I just got in to my settings and it does say Access Point.
That was a very easy changeover.
THANKS for the help in confirming that all is well.
SG
- plemansFeb 28, 2022Guru - Experienced User
