0xc000007e
Mar 28, 2020Aspirant
TFTP update on EX6100v2
I bricked my EX6100v2 and I am attempting to follow this guide at https://kb.netgear.com/000059633/How-to-upload-firmware-to-a-NETGEAR-router-using-TFTP-client however the blinking amber light never ...
0xc000007e
Apr 01, 2020Aspirant
I tried those methods above, TFTP succeeded and there was a green blinking light, so I waited 10+ minutes and restarted... still dead with a solid amber light.
nmrpflash did not work at all with the command nmrpflash.exe -i net3 -f EX6150v2-V1.0.1.86.img used only to be responded to with:
Advertising NMRP server on net3 ... -
No response after 60 seconds. Bailing out.
Tried both many times with the same result.
I'm basically on the same note as this thread https://community.netgear.com/t5/WiFi-Range-Extenders-Nighthawk/EX6100v2-blinking-green-light-of-death-tFTP-firmware-upgrade/m-p/1831243#M34403
Apr 01, 2020Guru - Experienced User
well if you read the conclusion to that thread, it was replaced. If yours is still within warranty, start the rma process. Click mynetgear at the top, register an accound and your device. From there you can go through the warranty process.
