Foshvad
Apr 12, 2021Aspirant
The best equipment for the 2000 sqft house + outdoor
Hi community, I have a great experience using Netgear in the apartment and need the advice to choose the equipment for the house. Internet source is LTE modem provided by the cellular carrie...
- Apr 12, 2021
Foshvad wrote:
plemans wrote:I'd go with a mesh system like orbi or the MK series.
They allow both a wired and wireless backhaul to be used.
I am afraid they don't:
Internet port (the Orbi satellite does not include an Internet port)
The satellite doesn't have a wan port but most of the satellites all have lan ports. RBW30 and RBS50Y don't have lan ports. I've used the others with wired backhaul.
Apr 12, 2021Guru - Experienced User
And being mesh, you won't have seperate ssid's to log into while roaming around.
In terms of specific device usage, you won't find that on netgears consumer devices (unsure about business grade devices)
Its a popular feature request on the "idea's" forum.
Foshvad
Hi plemans,
Thank you for your advice. As far as I see Orbi satelite ethernet ports work for output only:
If I use AC3000 as access point will seperate ssid be activated?
Thank you.
- plemansApr 12, 2021Guru - Experienced User
photos have to be approved by a moderator. Not sure what you mean by orbi ports are only good for output. they don't differentiate between input/output as both are needed for communications.
Are you wanting seperate ssid's?
- FoshvadApr 12, 2021Aspirant
I definitely need the same ssid in all places. Does the Mesh the only way to get the same ssid? What is the difference between router + 2 wired access points (repeater mode) and router + 2 mesh satellite?
Thank you.
