Evanf44
May 10, 2014Aspirant
The DNS server isn't responding
I have a WN2000RPTv3, I have ran the through the setup process to set up my extender. It connects to the network, and I can connect to the extender, but I have no internet access. When I trouble shoot...
TEC51
Hello,
I do not have the same extender but I just when through basically the same issue over the last few days. I ended up assigning a static IP on my computer via IPv4. As soon as I did this bang I was able to connect. You can access IPv4 settings by opening properties on your wireless network adapter, then properties on the IPv4.
Good Luck
Good Luck
