xhack89x
Jul 14, 2025Aspirant
The netgear_ext network is no longer being created (NETGEAR WiFi 6 AX1600 EAX12)
I purchased the NETGEAR WiFi 6 AX1600 EAX12 (model number: EAX12-100PES), and it has worked perfectly until recently. Suddenly, none of my devices can connect to the extender anymore. The WiFi ne...
CrimpOn
Jul 14, 2025Guru - Experienced User
xhack89x wrote:Full reset of the device (multiple times)
If pressing the Reset button (inside the tiny hole on the side of the case) for more than 7 seconds does not return the EAX12 to factory settings and begin broadcasting NETGEAR_EXT, my guess is that the EAX12 is dead.
Fortunately, WiFi extenders are relatively inexpensive and readily available.
