Br3tt96
Mar 24, 2017Follower
The possibility of having two N300 Wifi Extenders?
So our router gets great signal around our house, but for some reason our little streaming stick devices that plug into an hdmi port have a hard time getting signal. Laptops and consoles work just fi...
schumaku
Mar 25, 2017Guru - Experienced User
Hi,
You can add more then one extender direct to the same router, ideally from locations where all three devices (router, two extenders) can "see" each other.
Netgear does suggest using dedicated SSIDs (network names) for each extender to avoid confusion.
Set-up a daisy chain - nothing is blocking you form this set-up) - will lead to a performance impact.
-Kurt.
