scubadyer
Feb 16, 2016Aspirant
The word "NETGEAR" periodically flashes on my range extender
EX6200 It's really a simple question that Netgear "support" cannot understand. I'm not asking about function lights. It's the big brand name in the upper right hand corner. The label, the name, t...
- Feb 24, 2016
I gave up and bought a Linksys extender. I works better. Thank you for your response.
clithes
Feb 17, 2016Prodigy
I would check that you have the most up to date firmware to start with, link to newest below:
http://www.downloads.netgear.com/files/GDC/EX6200/EX6200-V1.0.3.68_1.1.104.zip
Often LEDs flash when data is being transferred, but never heard of the Netgear Logo doing it before.
If you go into Advanced Settings on the extender there is often an option like 'LED Control Settings' or similar. You may be able to turn the Logo off completely
Hope this helps.
