Dmnmay
Apr 23, 2024Tutor
time stamp epired EX7300 & EX6100v2
hello, i unplugged my Netgear EX7300 extender to go on vacation. when i came back and plugged it in my wife said it was no longer working? we had got it used a few years back and worked fine to get w...
- Apr 24, 2024
im gonna go ahead and order a new one.
did a little home work.
looks like all i need is the Netgear EX5000.
since i dont need mesh and only need to get about 75' outside a bedroom to a shed.
the 2018 EX7300 i had worked fine until it didnt LOL
wallmart wanted $54.00
fred myers had a same TP version for $44.00
found amazon had the EX5000 for $38.00 without prime.
simply wait 5 days.
but i did come across a EX6120 with the antennas for $38.00.
so im gonna get that one.
The EX6150 has antennas & mesh capabilities which i dont need.
hopefully the new updated version will fire right up.
thanks again for all the help i appreciate it.
maybe this experience thread will help somebody.
have a great day.
Apr 23, 2024Guru - Experienced User
I'd first clear out all browser caches before entering the extenders web pages.
Be sure the extenders FW was updated as well.
- DmnmayApr 23, 2024Tutor
so i unplugged the extender
cleared the cache on chrome
restarted the computer.
plugged the extender back in ( with factory reset )
turned on the computer.
proceeded to set up.
after a few steps it pops again?
thanks for the reply.
anything else i can try?
- FURRYe38Apr 23, 2024Guru - Experienced User
Can you get the EX setup using the Nighthawk app on a mobile device?
what is a FW update on the extender?
not sure how to do that?
If you can get the extender setup and working thru the NH app, then try to log in to the EX web page to update FW using your PC.
i do believe i am in over my head?
since these two extenders are 4-5 years old i wonder if its best just to throw them in the trash and go buy a new one?
or will the same problem persist?
i wonder if netgear does this on purpose so people like me are forced to go buy new products?
ive been messing with this for 2 days.
my head hurts.
thank you so much for trying to help.
i really do appreciate it.
