Dmnmay
Apr 23, 2024Tutor
time stamp epired EX7300 & EX6100v2
hello, i unplugged my Netgear EX7300 extender to go on vacation. when i came back and plugged it in my wife said it was no longer working? we had got it used a few years back and worked fine to get w...
- Apr 24, 2024
im gonna go ahead and order a new one.
did a little home work.
looks like all i need is the Netgear EX5000.
since i dont need mesh and only need to get about 75' outside a bedroom to a shed.
the 2018 EX7300 i had worked fine until it didnt LOL
wallmart wanted $54.00
fred myers had a same TP version for $44.00
found amazon had the EX5000 for $38.00 without prime.
simply wait 5 days.
but i did come across a EX6120 with the antennas for $38.00.
so im gonna get that one.
The EX6150 has antennas & mesh capabilities which i dont need.
hopefully the new updated version will fire right up.
thanks again for all the help i appreciate it.
maybe this experience thread will help somebody.
have a great day.
Apr 23, 2024Guru - Experienced User
I'd first clear out all browser caches before entering the extenders web pages.
Be sure the extenders FW was updated as well.
Dmnmay
Apr 23, 2024Tutor
so i unplugged the extender
cleared the cache on chrome
restarted the computer.
plugged the extender back in ( with factory reset )
turned on the computer.
proceeded to set up.
after a few steps it pops again?
thanks for the reply.
anything else i can try?
- FURRYe38Apr 23, 2024Guru - Experienced User
Can you get the EX setup using the Nighthawk app on a mobile device?
