Retired_Member
Feb 10, 2013To All Those with WN3000RP Connection Problems
I see lots of posts here about people having problems with this unit. You should be aware that earlier versions of firmware had lots of problems establishing and maintaining connections with the ro...
Retired_Member
Mar 19, 2013I meant channels ONE six or eleven, not two.
DarrenM
Apr 28, 2017Sr. NETGEAR Moderator
I would try a factory reset again make sure you hold the reset button for 10+ seconds and then set up the extender again.
DarrenM
