Eliza
Aug 11, 2011Aspirant
Trouble connecting iPad and Mac Mini to WN2000RPT
I have an existing home WiFi network running off a Linksys Router, I connected a Netgear WN2000RPT extender to the network, got it up and running fine, and was able to connect my Toshiba laptop to the...
jmizoguchi
Aug 11, 2011Virtuoso
I am using the same password on botht MYNETWORK and MYNETWORK_EXT.
two different SSID name so same pass phrase should not cause the issues.
did you WPA?
WEP are not favorable encryption to use anymore so would avoid and also hackable as well :)
