LindaPat
Jul 31, 2013Aspirant
Trouble connecting WiFi extender WN2500RP with WNDR3400v2 router
I'm new here and having a connectivity issue with 2 Netgear products. I have a Netgear N600 model WNDR3400v2. I have no issues with this unit except the signal is not strong enough in my son's room 2 ...
Gary7701
Oct 22, 2015Aspirant
I have seen this response before on other questions regarding being unable to connect. But unfortunately it's not clear.
When I use the Genie
Step 1. is identifying the router - so we choose the name of our router
Step 2. is providing the wi-fi password - but my router is configured already as WPAS-PSK
Step 3. my router is not 5g compliant so I SKIP this step
When I click Continue the extender is attempting to complete the connection of Router - Extender - Device
and we all get the The extender was not able to connect error msg
How can I avoid using WPS? There is no option in the Genie
How do I scan my SSID of 3400? Also do not see any option to do this
Put the encryption key 3400 where exactly?
What specifically are you telling us to do?
Thank you for your assistance.
Gary7701
With nothing else to do, I am carefully reading the manual.pdf that was referenced above.
So the first observation is the Genie app on my computer does not match what you see in the manual.
Specifically pages 11 & 12. The options on the screen print do not match what is available to me on my screen.
Certainly #2, #3 & #5 are not something I can do with this Genie.
And then pages #14 -16? How do I access those screens?
Configure the extender, sounds exactly what I need.
How do I get there?????
- nhannOct 23, 2015NETGEAR Employee Retired
Hi Gary7701,
Can you please provide screenshots of what you do see on your computer?
Please note that the Genie app that you've downloaded:
http://www.netgear.com/home/discover/apps/genie.aspx
Will look different from the web interface. Type this address into your internet browser (please be sure to connect to only the WN2500RP WiFi network, the name is usually followed by '_EXT'):
mywifiext.net
The instructions you see in the manual mentioned above are according to the web interface.
- Gary7701Oct 23, 2015Aspirant
nhann,
I did not download the Genie app. I am decribing the Genie wizard that comes up automatically when setting up the extender. It is the browser version although it technically is not on the web- because I cannot get the extender to make the connection.
The lights on the extender are all green as decribed in the manual, but the Genie fails to make the connection between the device and the extender as many others have described in the community.
- nhannOct 28, 2015NETGEAR Employee Retired
Hi Gary7701,
Can you please confirm that the WN2500RP connected with your WNDR3400v2 is WN2500RPv2 ?
That may be the reason why you are seeing different screens than in the manual mentioned above.
Please see the v2 manual: http://www.downloads.netgear.com/files/GDC/WN2500RPV2/WN2500RPv2_UM_28May2014.pdffrom: http://support.netgear.com/product/WN2500RPv2
I have also confirmed that the setup of WN2500RPv2 is working with the WNDR3400v2 as seen below:
To the left is the WN2500RPv2 mywifiext.net interface, which shows connection status as "Connected"
To the right is the Genie app to show the network map of the setup I created. The WN2500RPv2 is connected to the WNDR3400v2 with access to internet.
Please be sure to first set up the router by connecting to the router's WiFi then log into routerlogin.net
Then connect to the Extender's "_EXT" network and login to mywifiext.net and use the router credentials to extend the network.
If you are still experiencing issues with setting up your network, please contact support for further troubleshooting:
http://support.netgear.com/general/contact/default.aspx
