fchasseux
Aug 23, 2011Aspirant
Trouble Firmware WMS5316
Hi, I recently bought 1 WMS5316 and 2 AP WNDAP350. I boot the wms5316 and click on every menu with firefox6 on W7 32bits - Everything is ok. Then before to tune all the stuff, I decide, like ...
broadld
Sep 01, 2011Aspirant
We are resellers for Netgear and have a case open with them. It is with there level 3 engineers now!! But i have been sent a workaround. You have 2 options:-
1. You can either reset all your Access Points to factory default and then run auto discovery and it will find them all and let you add them
Auto Discovery apparently Only scans the default subnet of 192.168.0.0/24
2. IP Discovery: Must be used for any other subnet, can only scan 24 maximum at a time.When scanned, the found Access Point don’t show up, you have to click the Access Point Discovery they should show up under the Auto Discovery tab
Personally i did the first option and factory reset them all and it worked like a charm. List all access point and gives you the option to fill in the new IP address for them all!!
If i hear anything else i will pass it on
Thanks
David
Thanks
David
