outsideinfluenc
Aug 08, 2022Tutor
Trying to change Extender password
I just finished setting up my account here and it showed me the passwords on the extender, but there doesn't appear to be any way of changing them. I can't find it anywhere on this website. How do ...
- Aug 09, 2022
So you got it setup and working as you wanted it?
If so, you can mark it solved so others aren't trying to fix it.If not, let me know what issue you're running into and I'll do my best to help.
outsideinfluenc
Aug 08, 2022Tutor
I think I got it, thanks.
Aug 09, 2022Guru - Experienced User
