SeaBuzzard
Jan 02, 2023Aspirant
Trying to connect 2 EX3110 WiFi Extenders to my network.
I want to connect 2 extenders to my network, one on each end of my house for a Ring camera mounted there. They both seem to be connected to my network, but it seems that my 2 Ring cameras both connec...
- Jan 03, 2023
Thank you very much, it worked!
Jan 03, 2023Guru - Experienced User
If you log into whatever router (you don't say) that you have them connected to, it should have a attached devices page (or equivalent). Us that to find out the ip address of the extenders. You can log into it with that ip address and modify it.
SeaBuzzard
Jan 03, 2023Aspirant
Thanks for your reply. I'm using Verizon Fios, and my router is Fios_Quantum_Gateway.
I can see that both extenders have different IP addresses, but the same name (EX3100) a screenshot is attached. How would I log into them to change the name? Is there an app for that, or a website I would put in my browser? Also, would my computer or iPhone need to be connected to that WiFi device?
- plemansJan 03, 2023Guru - Experienced User
Simply type their ip address into the web browser. It should navigate you to the extenders gui to manage it.
- SeaBuzzardJan 03, 2023Aspirant
