uk2usa
Jul 06, 2012Aspirant
Trying to establish a connection with WNCE2001
Hello all, first time poster... I have been trying to connect a WNCE2001 to my home network so that I can provide a more consistent signal to my internet ready bluray player. I am pretty new to ...
jmizoguchi
Jul 07, 2012Virtuoso
This is how it should be setup
Windows 7
Plugs USB power adapter and plug provided ethernet cable to the WNCE2001
Once the Power LED is solid green, unit is "GOOD"
Open the browser and should open URL http://www.mywifiext.come/welcome.htm
Choose language
Hit next and it will go through status bar and look for "available" wireless network with following
SSID name
Channel
Security type
Signal Strength
It also includes "manually input my wireless SSID" for use who hides broadcasting of SSID
Choose your SSID and hit next
Provide your pass phrase and hit next
It will go through the status bar for connecting to the wireless router. After 1~2min it should come up with "You have successfully connected to wireless SSID NAME "
HIt finish. It will also ask you to save to your browser's favorites list. Close the the browser and open browser again
If you are using Win 7 it will ask your "network location" you can close or specify the type and save it
